I searched threads and found very little information. I've been catless and just added a 3.5 ETS as it got cold, and now I am getting cut from creep... but it is inconsistent. Either it sits at 16 or it creeps as high as it can get (over 20) before it cuts.
Solutions: Someone mentioned the wastegate valve could be bumping my downpipe and not opening fully. I would map clamp but I don't wanna boost to like 25 pounds or sit on anything higher than like 18psi. I can't use a boost controller to turn the boost down right? What if it's not a downpipe issue, do I need to modify the wastegate?
