Okay, so now after reading all this....I think I'm even more confused then before. Especially if you guys are stating that the HID stock projectors are different then halogen stock projectors.
Another thing is that all the different brands yield different color results. Most likely this has to do with some being cheap Chinese products, and others being Japanese and German products. The kit I'm looking to purchase is the XTREME HID kit from xenon experts which is pricier then most generic kits, but seems to use good quality products:
- Patented Digital Ballast Technology for precise colour illumination
- Japanese quality and craftsmanship
- CE, UL, and E4 certified OEM Grade Xenon HID Components
- Epoxy sealed Waterproof and Shockproof HID Xenon Ballasts
- Laser aligned HID Xenon Bulbs to ensure optically correct beam patterns
- Unique dual relay harness design
- Full replacement warranty
BALLAST SPECIFICATIONS:
- Xtreme HID ballasts are designed with a patented multi stage safety feedback (M.S.S.F.) system allowing them to interact with the bulbs to determine optimal light output.
- Xtreme HID ballasts use a patented self intelligent light output configuration (S.I.L.C) to ensure brightness stability and precise illumination colour.
- The Xtreme HID ballasts are designed for both 12V and 24V applications.
- Equipped with advanced polarity protection system
Now that being said, I can't find 4500k anywhere? OEM is 4300k which is found on every website. And if I were to just pick from the images below, I would go with the 4300k....but the problem is 4300 looks so different on every car I've seen??? Does anyone on here have this exact kit from
http://www.xenonexpert.com/
This is the picture of their 4300k
This is their 5000k
And finally 6500k
