Straightening bent intercooler fins?
AutoEuphoria
'08 CPW Mazdaspeed 3
Is there a technique to straighten bent fins on the intercooler? I somehow bent a few of them over pretty good...and bugs and things have bent a few others a bit, too. I'd like to straighten them, but am not sure if there is a technique that works quickly and well. Anyone have any suggestions?
even small needle nose pliers, anything that you can get in between the fins with will work. just be gentle.
topher why did you have to bring it up now im going to have to sing it a t work all night. eerrrr.
you can also get a tool for it. ill see if i can find a pic of it sometime tonight.
here is the tool you can find them for $10
condenser fin straightner
tool works great if you have a lot of bent over but if its such a small area its cheper to just do the twesers small flathead screwdriver.
but be careful - to get the most heat transfer, those fins are pretty thin/weak, which is why bugs can bend them. you might do more harm than good.
