Metallic36
- 2003 Mazda6 3.0L Speed Yellow
Just noticed this recently before my car was taken into the shop, and they couldn't solve the problem. My theory is the wastegate actuator, although I could not blow any air through the hose. It just started doing this, after taking off the Unichip and the Unichip EBC. I still have the stock cold pipe on the car, but it is tight. Anywayz, when I am driving it and want to go into boost, it gets to around 4K rpms then bogs down like the car has lost all power, and jerks a little, and of course I get no boost at all. Here are my thoughts on what it may be, just needing some input so I know what to fix next.
1. Coil packs
2. Needs new plugs
3. Wastegate actuator needs replaced
4. Issue with the vacuum line routing (?)
5. EGR needs cleaned
1. Coil packs
2. Needs new plugs
