I think I blew my turbo
protur03
2005 Mazda RX8
I have an 08 mazdaspeed3. Im running Injen intake, FMIC, Full exhaust, 19psi. no tune.I just installed the front mount, i was lacking Tbolt clamps so i was stuck with basic clamps. I was initialy building up the boost and finally got to full throttle with no problem what so ever, strong pulls consistantly. Then i blew a pipe off the intercooler piping. after i put it back together i searched and made sure there where no other problems. I start driving and building boost but the car dies at like 4psi. The car just dies, I got no smoke out the back, no check engine light. the car only has 8000miles on it. help! whats wrong?
Take off all your mods, bring it in to Mazda and have them repair under warranty. Upping the boost on this car is a major risk, I wouldn't advise.
that not your turbo, and thoguh 19psi is too high its not a big deal to up your boost. Just keep it around 17-18 max unless you have meth. If you blew your turbo it would prob be making loud noises..
same thing happened to me, with similar mods. well, i didnt blow any of the intercooler piping. the way that the stock bpv bolted onto the front mount flange wasnt sealing it very well, so i got a forge and the problem was solved
check the turbo for shaft-play and look at the compressor wheel and see if the fins are bent...thats the first thing i would do if i thought my turbo was shot..
i can tell what is wrong, your an idiot. what were you thinking trying to make that much power with no engine management??? and i hope mazda doesn't fix anything for you under warranty either.
You have no idea who i am brealmp3 so why would you say something so hate full? grow up man. the car hit 19psi in 6th gear all other gears are no more than 16.5 to 17.5psi. plus i have a wide band just in case. Dont worry though smart guy carma is a bi***
I also don't think 19 psi would cause a problem assuming this was indeed the Max. boost you hit...I would go over once again every boost tube/boost-seeing line and reconfirm there is not a leak...make yourself a boost tester with PVC pipe/cap and a tire valve and pressurize her to 20psi and see if you have a leak...could be in that new FMIC where it isn't evident.
Thanks fasteract. as soon as i get out of wok im just going to redo the entire thing because i still need to position the intercooler correctly anyway cause its off center a bit. even though im still running a little rich im going to lower the boost cause it is a scary thought to run almost 20psi on a stock system
dude whats with the attitude the op just asked if we think he blew his turbo and you answer like that, whats your ******* problem dude, chill the **** off.
thanks man. by any chance BLACKMICA08 do you ever go to the hang outs on 27? If you are who i think you are I belive i met you at the u gas awhile back? I got the black 08, i told you i was getting the front mount put on last week. i could be wrong though because i dont remember you having different wheels.
is it the wrong time of the month for you or something ? .... sheese
ya thats kinda a d1ck thing to say. this car is still very new to the sceen and people are still learning what the motor is capable of.
