turbotaylor
- 2003.5 blue msp
screw the evo.
hahahahaa (yippy)
screw the evo.
Yea but will it still make the whole BOV sound? know what i mean?
the car is not designed to vent to atmosphere. frankly you should not be buying a bypass or blowoff valve to make a sound. the function of such a valve is far more important. the car tunes from a Mass Air Sensor. venting open, sound or not, allows the sensor to see a rapid amount of air flow loss/change and thus it will attempt to compensate with appropriate fuel and timing adjustments. normally this leads to a loss of power across the board and between shifts.
if you run a cold air intake and recirculated Forge or HKS valve, you should still net a great deal of noise while doing it right
