- 03.5 YLW MSP
boost leak?
not that im aware. it idles nice and holds -20vac with ac off and around -16/-17 with ac on.
boost leak?
I can hear it spool up, BOV blows off, and doesn't reach full boost tell about 3.5k-4krpms. Some days I can tell its FI due to the pull of the car and other days its just noise or well feels like it.
my car is still in the shop after having it for a month and i've never been able to boost it.hopefully we'll figure out what's goin on soon. they think it's an ecu problem.
my check engines on it says an idle sensor when im sitting it revs up and down
i found one thats a universal called eip tuning would that work or does anyone know someone that has one for sale because i think thats the problem
what are you using for the closed loop o2 control? the haltech has to see a signal from either a narrowband sensor or a wideband sensor. and i thought you said you removed the narrowband from the exhaust...so wideband?
well ok now what happens is when im driving normal like not flooring it it runs good but when i get on it, it starts making like a puttering noise not like a backfire more like a kind of like when your going to stall i guess but not exactly it still spools up and kicks in but pops but usually only when i floor it. it used to do it when i first started it up and drove for like the first 15 minutes but then it would stop is that better details or should i wrrite it in another thread im new to this
i just tried blowing into the vacum hose running into the wastegate and it was real easy to do so ill try looking at my check engine light and check to make sure if thats not a possibility of fixing the problem
