Picture from drivers side rear rotor not wearing properly. Just saw this last night.
it is a decent groove too
no but I will why do you wonder?
Both grooves are about .08 deep. And I"m hearing an oscillating rubbing sound. Do you think the wheel/rotor is moving sideways or that its bent?
Problems worth noting ... I have this gremlin suspension noise. Traveling over expansion joints for example I get a "CLINK" sound. Same place worked on it and mentioned it may come back and that they elevated the issue and reported it as a quality problem to mazda. Upper strut mount bushing (off the top of my head) was replaced however with the same designed part.
I'll keep an eye on this one. its documented so if it occurs again there's a bigger problem and the pad was only the symptom.
Sounds to me like you have the exhaust donut noise noted in a TSB. Every small sharp bump results in a weird noise coming from the front of the car.
whadja get btw pleaseit seems like they either arent torqued right or the rotor is bent when i bought mine the front ones were both like that so i justgot new rotors and upgraded when i was there
YES that is exactly what happens... can you elaborate though because, maybe I'm just naive, I'm not familiar with what you're referring to. You know what TSB it is?
