What Clutch
I had a bad experience with a exedy stage 1.
If I recall correctly, your experience was a direct result of the moron that installed the clutch for you. He neither resurfaced your flywheel or installed a new one. Any clutch set would have provided a bad experience under that condition.
FWIW, my Exedy stage 1 has over 50k on it and I still absolutely love it.
i run an Exedy Stage 1 and love it. never had a problem with Exedy clutches.
i carry both Exedy and Spec (ACT too) and will cut you a deal on a new clutch if you want. PM me!
thanks, I've never ordered from you before (yes, I should be flogged by ugly midgets) so I'll pm you when the time comes:)
True, but I was still scared to put another exedy clutch on the car after that tho. I did like it WAAAAY more than the one I currently have. Used to grab harder, be stiffer, etc
I dont have an answer for your clutch problem, but did you bring your car to Swift Motorsports in Norwich, Ct if so that s*** is nasty fast they were telling me about it cause i live right down the road. I Just got the New Q unichip also
