My First Cel
Killer
2011 3 5 door
Used some degreaser and cleaned my engine bay yesterday...now I have a CEL.
Going to do a battery disconnect and reset the ECU and see what happens. Also, for some strange reason now my powersteering pump is making noise.(scratch)
26k Miles 2006 Speed 6 first problems eVar!(deadhorse
Don't use that crap on an engine with only 26K. Nothing should be leaking to cause you to need to degreaser. Soap and water will keep it clean. You most likely got a sensor wet. Go get it read for free at AutoZone before clearing to see what it is though. Spray some lubricant on the pump bearing behind the pulley.
It was Simple Green and my hose. A light washing to keep the dust and dirt down, I had no leaks. I have done it twice so far without an issue.
simple green shouldnt have affected the engine in any way...
something probably got more wet than it should have...
hows the car running?
I'm all for keeping the engine and bay clean. I don't like the way degreasers, no matter how mixed make certain parts look afterwards. Especially polished aluminum ones. I use my pressure washer and car wash soap. Never had a cel or problem after many washings.
car wash soap cant always cut a dirty greasy engine.
Professional detailers use a variety of degreasers to clean engine bays.
Personally ive started using Megs APC+ (diluted) to clean and Megs Hyper Dressing (also diluted) to dress
Remember were talking about a reasonably clean albeit dusty engine. Soap and water will work fine on that. Now if I'm cleaning a diesel engine or a high miler than I'm breaking out the HD stuff as I don't have time to waste getting it clean. But for my own leak free engines and their blinged out parts its just the mild stuff and frequent washings.
Like a ***** ape as usual. The CEL is now gone...after my ECU reset, but the power steering is still whining. I made an appt. at the dealer for Wednesday, driving the wifes 3 until then.(eekdance)
not smart to stick a hose under the hood...
Why didn't you take it to autozone to have them scan it so you would at least have an actual code?
You will not hurt the engine washing it. I use an air compressor to help the drying process before toweling.
Subn to see what the dealer told him about the whine.
Please explain why this is a problem when the engine is cold. I can hardly wait. (lol2)
Because it went out the very next day.
OK...dealer just called. I am getting a new clutch! WooHoo! I just complained about how it was still hard to depress and jerky and they said they will replace at no cost.
Power Steering required some lube on a bearing or something. I get the car back on Friday.
If you stick a hose under the hood you are asking for an electrical component to fail. Simple green on its own should be good enough to clean everything and it's more controlled using it on a rag rather than spraying the engine down.
Funny, in my 48 years on this planet nothing has ever happened to any of the cars I have ever owned while washing down the engine when cold.
While I appreciate your concern, you really have no idea what you are talking about. have a good day.
Before you spray with water:
I don't like to spray down a hot motor. If possible let it cool for 15 to 20 minutes if you have driven it any distance. If the engine is cold, then start it and let it warm up some. 10 minutes is plenty, and let the engine cool a few minutes so the exhaust manifold isn't hot.
A good idea is to spray down the dirty areas with a product like simple green. This cuts dirt and grease well and is easier on the paint/connectors and environment than typical foaming engine cleaners.
Use a soft bristle paint brush to work on stubborn spots, a brush can also get into crevasses better than your fingers in many instances.
Next if you have a hose available, gently rinse the area and see if you got most of the dirt. Touch up any spots you missed. If using a high powered car wash wand, then use only the rinse cycle and don't concentrate on the ignition parts and don't spray directly at any exposed air cleaners or air intakes. If necessary, put a plastic bag over those components. It's also a good idea to cover traditional distributors on older cars. The coil packs of newer distributor-less ignitions generally don't need to be covered.
Be sure to rinse off the fenders, especially if you have rinsed off any battery acid!
When through rinsing, take old towels and wipe down any shiny painted surfaces or those that might spot, like manifolds or chrome accessories. It's a good idea to start up the engine as soon as possible and let it warm up. A brief drive will also get rid of puddles that could start rust.
Take rags and wipe down any surfaces you can get too.
http://www.dccarcare.com/tipowk/tipowk13.html
If you don't get it, it's not worth my time to explain. It's almost pointless trying to help people (mods included) on this forum...
Good luck.
LOL...I challenge you to find me a link that says it is dangerous or unadvised to wash your engine bay on a modern automobile..
OK GO!
He probably read that on some internet site about detailing and does not have the benefit of wisdom or age.
