15 psi???????
oskinosmee
07 mazdaspeed 3
Ok i was driving earlier and i decided to open her up and i did. I got a loud backfire and a lil smoke which i thought was normal and i kept going. So i arrived where i was going checked my exhaust tip and it was black, now when i gas it i only get to 15psi no higher. Also i hear my wastegate opening i think. I had it set to 18psi with a MBC, it would spike to 21psi a fall. Whats wrong?
Thanks in advance Steve
something from the stock EBC is still connected and taking control of your boost levels? or maybe a boost leak or something? how long has the MBC been on the car?
Update.
Ok i took the MBC off and tightened everything down and the same thing happens except it doesnt hold boost or build boost
I dont have a boost controller but i had a simillar experience:
I also noticed some backfiring with my car especially when shifting in low revvs (driving normally). My car is mostlly stock with just a MSCAI. At first i thought nothing of it for a few months but then i realized that wasnt good for the Cat converter and it didnt sound right. So i went out and changed the BOV, the shop attendant recommended me to buy a turbosmart dual port running and run it hyrbid mode but still i was getting the popping noises back there. It didnt matter how much i set the dial to harder or softer; the car would still backfire occassionally. So i decided to run it in full recirc and those popping/backfiring noises have been 99% cured. the problem all along with my car was the stock bov.
good luck
good luck
ok well i changed my bpv back to stock and still the same problem. any other suggestions? It only boost 6 to 10 psi with a loud squeaky noise
good luck
You have your Turbosmart running recirc? You set it to "Harder"?
Maybe you killed your turbo? Does it still smoke a lot? Black smoke or blueish/gray? Maybe your ECU reverted to limp mode after sensing an overboost?
i would take everything that put on the car and run it for a few days /weeks and see if anything changes. take off hoses and put them back on to ensure a good seal
