DownPipe Install
RichB
2007 Cosmic Blue Mazdaspeed 3 GT
Is there a "How To" on a downpipe install? What about a scanned copy of instructions?
thought id post this to help people out as recently wev had quite a few people having problems with bios
all the beep codes are different depending of who makes the bios , but here are some of the more common ones
What is a BIOS Beep Code?
When you power on a computer the BIOS immediately takes control of the computer and performs the P.O.S.T (Power On Self Test). At the end of the POST the computer will play an audible 'BEEP' through either the PC's internal speaker of through speakers attached to the sound card (if you have a built-in sound chip). If the POST completed successfully without detecting any problems with then system will play a single short beep to let you know the test is complete and the computer will continue to startup and load the operating system.
If during the POST the BIOS detects a problem it will normally display a visual error message on the monitor explaining what the problem is. However, if a problem is detected before the BIOS initializes the video card, or a video card is not present or not detected then the BIOS will play several 'BEEPS' through the speaker to let you know there is a problem. Depending on the type of the BIOS you have the BIOS may play beeps in a specific pattern to indicate what the problem is, or play the same beep a number of times indicating the problem. It is very important that you pay close attention to the number and/or pattern of the beeps your computer plays on startup.
Below is a table of the most common AMI, Phoenix and Award BIOS beep codes.
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video cardthought id post this to help people out as recently wev had quite a few people having problems with bios
i just got my TurboXS dp in the mail today, i will be opening it tonight and most likely installing it Saturday. I will see if i can get my scanner working to send you the instructions.
That'd be awsome! Thanks!
Well just opened box and no instructions. Looked on there website and they ont offer instructions for this product. i guess im ******.....
just called up, it was a little mistake theythought id post this to help people out as recently wev had quite a few people having problems with bios
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card forgot to put the instructions in the box. They are emailing them to me as we speak i will try to put them up...
well if you don't get it done or you want someone else to do it for you. you can can visit us at P3 performance and we can install it for you!!
it is not the issue of HOW TO do it is it having the right tools to do it makes a world of difference!! If you don't all the instructions in the world will not make the job any simpler.
I can explain what you need to do. The doesn't make it any easier though.
Care to share you knowledge on this install?
the instructions they sent me are useless, they are one page long and tell me how to properly bolt the dp to the mp...
I am back to square one, probeturbo please do share share knowledge on install. I could care less about ease,, i need knowledge...
ok well first this is what i would do:
First make sure the car is HOT.
Take off all the heat shields as fast as you can because you want the DP to be hot or as warm as you can with taking that 02 sensor out. Then take the o2 sensor off. If you manage to get that off without stripping it then you take take out off the DP bolts. There are 5 bolts i think 17mm. Once you have that then go under the car and take the Dp apart as it comes in 2 sections. (that info if moreso for the speed6 guys) I think you can take the whole DP from the bottom on the speed3. I might just be easy to just take it apart though. Then disconnect from the catback. There is also a bracket that holds the DP to the motor. It should be 3 bolts i think 14 or 17mm. you will not need this bracket again.
One point is when you re-install the new DP DO NOT TIGHTEN ALL THE BOLTS to the turbo untill all the nuts have been snugged to the bottom of the stud that it reside on. the reason why this is because for ex... if you tighten the bolt in the rear near the fire wall and then you go to put a socket on the one closest to the motor the socket may not fit on the nut due to the DP shifting because the bolt holes are a little larger than the studs and also the design of the DP can prevent you from getting a socket on there. Then you have to loosen all the nuts up and try it again.
This is a ROUGH set of directions and my thing is if you are slightly mechanically incline this will not be for you.
if you pm me your email address i will email you the cpe dp instructions.. it is a very big pdf file so be aware
The Corksport instructions I have and I needed some help from a brother in how to. i think it is on the disc happy to send it if you need. There are some tricks that might help. One is to spray the o2s or use the natural engine temp to open the thread up. And having swivels and extensions for ratchets. You're going to get pissed. I hope you have a helper. If only to hand you the tools you forget when into it. Well worth the work though!
I did what probeturbo mentions, I took everything off the top of the engine right when I got home from work while everything was still hot. My top 02 sensor came right out. Then I sprayed the turbo bolts with PB blaster right before dark, then again after I ate, then again right before I went to bed. Then when I woke up I went out put a socket on them and they came off with little trouble. Once I removed those bolts I got under the car and removed everything else.
This install requires various types of tools and creativity to get to some of the bolts. It's a pain, but well worth it.
turbo bolts are 14 mm shallow and deepwell diffrent thickness help. 22 mm i belive is what the 02 sensor is its a generic size. pic is from autozone website. antisieze bolts before you out all back togeather that way you can remove later if you need/want to. make sure engine and exhaust is warm when removing
Glad it worked for you!! If any of you are the md, dc, va area come visit us a P3 Performance!!
