happy and angry
I'm going to make up pretend numbers here to make a point. I'm going to be general with the numbers and keep things simple.We are both overweight and tend to carry 100 or so pounds of extra stuff (mostly wife's work stuff, laptop, etc) around with us. I am not convinced a little extra weight makes much of a difference in a 3k+ lb car with this much HP/Tq.
Let's say you have 310 pounds of stuff in the car. You and some gear. You have just added 10% more weight to the vehicle. That is 10% more weight to pull, and as a result about 10% more work to be done to keep it moving at a given speed, 10% more effort needed to accelerate up to speed, etc. That's going to burn a lot more fuel. About 7% more, actually.
http://www.fueleconomy.gov/feg/lightweight.shtml
For every 10 % of weight eliminated from a vehicle's total weight fuel economy improves by seven percent.
So let's add another 310 pounds to the car. Someone else and some gear. That's another 7% increase in fuel burned. Just over 600 pounds and you just killed your fuel economy by a good 14%, which is about 1.4 MPG for every 10 MPG your car gets. That's about 3.5 MPG for our car if you average 25 MPG.
Weight is one of the biggest problems when it comes to fuel economy and performance. Power doesn't matter. Torque doesn't matter. More weight, more work, more fuel burned.
