Springs and lip or tbe???
ComeBack
Mazda MazdaSpeed3
so im debating on what i should do. Its either a set of cobb springs and a front lip or corksports tbe. I cant decide on what one please help!
springs and intake.......
or springs, sway bar kit..
go with looks later, unless you're content with the power already.
TBE/CBE can come later...
or
TBE/CBE, and intake/DP...if you can afford it.. my pockets aren't that deep, so i'd go with the handling first.. =)
I am doing the lip and springs first. Too bad H&R springs are on national backorder for 1-2 months tho.
+ Cobb rear sway on mild setting.
rear sway ftw !!!
bye bye understeer .... hello very minimal understeer
seriously i just got my rear sways and it lets me throw my car in corners, just point and steer. Very very good mod to consider. There are two settings "stiff" and "stiffer" if you are only getting the rear, set on the "stiff" setting.
Is the lift-throttle oversteer that bad on the stiffest setting if you're rocking the stock FSB?
i don't have the front sways yet and im not sure im gonna get them. I wanted to try it out with the rears only first and am very pleased so far.
having both front and rear will give you a tight neutral car. Just the rear sways , you can feel the rear is tight and it reduces understeer. If you have it only in the front i assume you will get a butt load of understeer.
