Squeek when throttle
cosic
MS3
Just started last week. When I barely tap the throttle, or press it down with however force, there is a squeek that is coming from the front center console or maybe lower. Definately middle to driver side area. I know it is not the gas pedal itself, because I've tried this when the car still with engine on, and engine off. Anyone else
Can't wait for my next oil change. Mazda is going to get an earfull!
I want my tweeters and pretty much whole right door panel inspected and replaced. I'm going ******* nuts sitting in the cockpit of this car. The glovebox was bad enough as it is.
i have the same thing, it does it when I take off from a stop and brake..I'm going to take out the whole center console and see if it helps. I hate to admit it but it looks like im loosing the battle with squeeks and creeks.
its the drivers side belt...where you clip it in that metal piece down there needs to be greased up...this is common theres a few threads on it
That is not it. I've delt with that problem and have definately made sure that wasn't it
