Best Exhaust system out??
Quiksilver05
Mazdaspeed3
Im looking to get a new exhaust system for my MS3. Anyone have any recommendations or opinions on whats good and whats not from experience?
Or is the stock one good to keep? Thanks!! Sam
I'm not an expert, just in the mood to post ;) From what I've read and other people have said, changing out your cbe (cat-back exhaust) is really only going to net you 5-10 horsepower and in some cases, lots of unwanted noise (depends on who you are). When Mazda dyno'd 30 horses from their intake and exhaust, 25-ish came from the intake.... start there. Also, exhausts are expensive. If you want power, spend your money elsewhere. If you want noise, there are easier and cheaper things you can do to make noise (more on that later).
What you really need to make power on the exhaust side is a new downpipe and test/race pipe. The downpipe is a majorly holding back power. Turbo XS has a stealthback system for under $500 I believe which is just that, downpipe and racepipe. It should give you some growl, but maintains the factory cbe and mostly volume levels, yet yields great power gains.
If you are like me, I want something easily changed out or something Mazda won't care about in case warranty work is needed. I have ordered my testpipe to replace the second catalytic converter. It should help a little bit with power, but keep close to the same sound. It is also easy to change out. A lot of guys are having muffler shops weld straight pipe in place of their resonators and/or mufflers. I am going to have one resonator done for sure, and then see how I like it before taking further steps. When exhaust systems are easily $600, $40 for the "Midas Special" seems like a great idea to me.
If I'm way off bat, someone stop me, but I'm pretty sure I'm right on track. So what did I say? Oh yeah, factory cbe is alright, but lose the downpipe for sure, unless you are worried about warranty. If it's simply for sound, you've got a bunch of other options!
Yeah i don't want something thats real loud or too drastic. Just something that can help make the engine breathe better. Im still thinking about warranty for now too. Thanks for the great info bro!! (bowdown)
I ordered a cp-e catted downpipe. It doesnt increase the noise THAT MUCH, and it still sounds good. Good for quite a bit of horsepower too. The catback really doesnt gain much power at all, I've seen a dyno where it lost 1 hp, and gained 5 torque, so it's really not even worth it. I'd thinkabout a downpipe if I were you.
just getting downpipe, it will sound the same cruising around but when you go WOT it will sound a lot ballsier. It will actually sound pretty nice from the outside. I didnt realize it made a big difference in sound until i took video of my car
yup,Get a DP and a testpipe and you will be done with your exhaust.After warranty is up you may want a new manifold also.
my gf has a corksport 3in cbe on her ms3, in my opinion it sounds like a slightly louder than stock STI. the fitment was ok for the most part but where the last flange is toward the back, it didn't quite line up. i had to use three gaskets in order for it to seal correctly. other than that it sounds good (cant really hear it insided cabin while driving) and looks close to stock.
i also have a friend who won't shut up about his GHL, i don't know, but he loves it?.!
^ I know what you mean about that last flange. I put some copper gasket spray on it, should do the trick.
Corksport TBE with high flow cat
i actually kinda made my own third gasket from a gasket cutout aluminum sheet and layers of heat resistant aluminum tape it made for an awesome crush gasket type thing. certainly did the trick.
I really like that Corksport video…what a nice and not ricey/intrusive sound upgrade. I am always worried about getting something that will sound too rice...
I have the mazdaspeed exhaust..Its louder than stock but not too loud.. just loud enough for me..im happy with it as the car sounds better and pulls harder too.
As for the clips I've heard online, if I was going to go with a CBE it would be the GHL. Personally, I love the cruising burbling sounds it makes.... not so much the WOT though.
Early next week I am having a custom exhaust done. I am still debating what to do. My testpipe has been delayed again.... but that will make it in eventually. I am having the second resonator removed and the muffler. I am going for a small volume increase while cruising, but most aggressive sound. (I am a musician and music teacher, I am very picky about what goes into my ears ;))
I was torn between removing both res and muff, or just muff and one res, but its easier to remove more things later than to put them back in!!! I will post up when it gets done.
