Starting My First Mazda Build
X2 on that one. I feel like everyone on here is like "Yeah I drive (insert random Mazda) and my second car is a Miata."
OR
"Yeah, I got a (insert random car) and an RX-_, and a Miata."
Welcome.
Off the top of my head, I think the only individuals who have multiple Mazdas are Scott, Kevin, and Muff. I guess you can check back in with me in February: I'm considering the Mazda5 and MazdaSpeed3, but neither one is the front-runner.
I moved my filter a little further away from my exhaust manifold today so maybe now I can start getting cooler air through my engine. I started by cutting the baffles off of my stock intake, then I put a rubber sleeve on it to connect the intake with the mass air-flow sensor. I still have to fabricate a heat shield but this intake should do the job until then. At least I got it off the manifold. I was going to get a cold air Intake but someone very wise told me that it wasn't a good idea to put one on a '94, so I'm gonna listen. Anyway here are some pics.
Hey Jon, It is Austin the one who dives the speed 6. What happened to the green?
The green was cool but I thought it was a little overkill. I have always liked blue though.You can find alot more accesories in blue rather than Lime Green. Good to see someone else on here whose face I've accually seen before. hope to see ya thurs at the Flatt's.
I'm another multiple Mazda owner...'02.5 Protege5 & '90 Miata (along with my other cars). :) They're addicting and it seems that it must have been a good time to get a Miata recently. I've had mine since April...Still working on it's issues little by little...But it's such a fun little car to drive!
Anyhoo...Welcome!
Anyhoo...Welcome!
So you're coming out to the next auto-x. Awsome.
He's got more than just the intake to worry about in Stock. Does it have an LSD? If not, he could still be STS2 eligible.
not w/ the steering wheel. Not like he'd get protested locally... unless he started winning all of a sudden :p
So you're coming out to the next auto-x. Awesome.
I'm working towards next season. The engine still isn't running quite right & I haven't found a replacement. :( I'm getting ready to post update pics in the Miata section. :)
Yeah and good luck beating you, am I right?
Yea, me coming anywhere close to Kevin would be a long shot but anyway I went out for my first event and entered csp. I had a great time, got much needed instruction from Kevin, stalled my car out, and I'll definitely be back for more! but yea I came no where close to Kevin but I did have a faster time after each run. My lowest run was 100.115, which I thought wasn't bad for my first event. It was good meeting some of you on the forum and I will see you again. I'm hooked!!!
Run novice next time. You'll get an experienced instructor in the car with you. Let them show you what the car can do, and I guarantee you'll drop more time than you thought possible. Glad to see you out there, and that you had fun :)
