quick cobb intake question
stageup
so i just installed it, piece of cake.
that 90 degree elbow was easy as well, i just followed someone else's
suggestion and push in the 2 blue tabs to remove the top part of the elbow off.
after that you can just grab onto it and pull straight out of the stock rubber hose.
only question i have is where that 90 degree elbow goes, there's a little "notch" on top where it goes into the silicone arm. with the stock rubber one there's a notch cut out to make it fit perfect. on the cobb silicon part there isn't. did you guys just push it in and leave it with the clamp? there's a little bump on the top right? or were we supposed to "trim" a little notch out ourselves?
=D
i posted this in a diff thread towards the back, didn't know if anyone would see and answer so i created a thread.
