Corksport FMIC
Shane5425
Contributor
2011 Mustang GT
i like the setup, but here is my question, the ms6 has a bigger intercooler than the ms3 version? why is that , they are the same engine? btw i would rather the ms6 intercooler in the ms3....
I'm pretty sure the pipe routing is completely different also, I'm 99% sure the 6 part would not fit in the 3.
make sure that corksport has rectified their mass air flow housing problems before you get this kit!
I really like the CPe but I am just not sure it will suffice in the long run. also, it might drive me a little insane that the core is off center in the grill. pretty sweet that it fits any cold air intake though.
whats the UI mean in your sig?
upgraded intercooler I think. I dunno I just posted the time and the mods. all I have is an intake motor mount and an intercooler though....
I think it made a pretty big difference... I put the intercooler and the mount on at the same time and it was very noticable.
if you're serious about it, I'd get a front mount. it sucks knowing that the whole time you're staging, your intercooler is soaking up all of your engine heat. since you already have the cold air intake, I'd check out CPe's front mount. they claim it will fit any cold air intake, which none of the others do. if you want to replace the intake, the corksport is pretty nice.
Which intakes fit the corksport. I didnt realize that the CPE intercooler was off center. Is there a picture or something floating around?
yea sure
And squirting 150lb of the juice, ehh. jk jealosy will get me nowhere
Ice,Ice
Ice baby . it works. But you are correct about top mount and staging. Even with hood open she heat soaks. Front mount if you drag. period.
corksport has its own intake, it sites exactly where the tmic goes... its a ram air intake, the air box seals just like the intercooler does..
