It's funny to me to hear everyone hitting high boost numbers with Unichip when I can't get mine to boost over stock, even after sending it back to Unichip TWICE, calling them 10+ times, and trying everything I could to get the thing working. In the end they will not return my calls or emails, and the thing still doesn't work (the pin that triggers the valve never closes to ground, but I can manually ground it and make it open). I don't understand why they couldn't figure out what the problem was (even after they replaced the harness the first time after finding that it was miswired, and the solenoid on the valve itself was backwards from the factory) and just completely ignored me. The sad thing is that my $35 MBC can boost to anything I want, but the $800 Unichip can't do anything. They couldn't even explain to me exactly how the Unichip handles the boost valve so I could troubleshoot it myself (ie - should it be active while not under load?). I would think that it would be active (bleed any pressure away from the WGA) all the time until target boost is reached, and then pulse to maintain. That way the WGA is not starting to close until the last second, allowing the turbo to spool faster. Has anyone ever figured out why there are several of these out there that just don't work, and why do those owners just accept it and buy another boost controller? I'm starting to regret not contacting the BBB at the time.
