MBC and BCD
Double Dspeed
2007 Mazdaspeed3 w/ CAI, 10k HID
alright i read enough to make my eyes want to fall out of my head and between the AP, Reflash, CP-E standback, and what ever else i still have this underlying dilema. if i get a MBC and BCD cant i raise my boost and have full boost in first and second? that really the only thing that pisses me off is that resricted power. so what can i do to get that or am i looking at spending upwards of $680. i know this is stuff constantly talked about but i really cant stare at this screen anymore im gonna get dissy (smash) please i really appreciate the feedback
well your gonna have to map clamp it, and get gauges to monitor all your stuff since your messin with it, and probably have to eventually get a fuel pump to keep up with it all. it just goes on and on you could spend a little or alot what kinda power do you wanna make at the end of it all?
Why do you want full power in 1st and 2nd...? Its all wheel spin...useless.
What I would like to have is an increase in base boost to 17-18 PSI (3rd-6th gear).
well yes and no. the car still plays with the throttle so much that you will have higher boost as you go up in the gears. i see this....
1st gear......15psi
2nd gear......17psi
3rd gear.......19psi
4th gear.......20psi
5th and 6th...23ish
that is from a roll on. if i run through the gears 1st and second stat the same 3rd and 4th hold about 18psi and 5th and 6th hold 20 .
From a roll, the car could use more power in 1st and 2nd, IMO. Im not spinning much when rolling in either gear and I punch the gas.
