Fresh Tranny Fluid!
It's just kind of strange that it's only the 3rd gear that grinds with me if I rush it. The clutch is always fully depressed before I make the shift to 3rd; it's just when I do it fast and way up in the revs like 6grand that I will at times miss-shift the car. And it always happens when I'm running the 1/4 damnit! I don't see how people are power-shifting 3rd, it seems almost impossible to do
yep. i know exactly what you mean. that is when it'd happen to me a few months back when i got the car, when i was engaged in "spirited" driving. it would happen even in lower revs when i would test quick shifting out....
to me its the physics of the actual shift from 2nd to third. there is some sort of actuation difference within the cable system or the trans that makes it in essense what i think you could call a 'shorter' shift than the other gears ('cept maybe 4 to 5, but that rarely is a rushed exchange). the throw is the same, but the actual actuation is very rushed. so, what i'm trying to say is, it's alot more sensitive to the clutch engagement because of how quickly the cable system takes itself out of second and how quickly it goes into third. it's my opinion that yes, mazda could have possibly played with some leverage options in the cable system OR in the actual exchange area of the trans to make this timing more uniform across all gears, but they didn't and i can't even be sure it's possible since all of this is hypothesis.
my body adjusted to it; maybe it's because i'm a drummer! (band)
same here, only issue is 3rd gear so it makes no sense with the timing suggestion. i think its an issue with 3rd gear it self, and with 900 miles on the car it just pisses me off
I'm guessing the engineers that designed this car just didn't catch everything.
When they drove it they probably didn't shift it all that fast and pretty much took it easy on it and said it was good. Now here we are with a ****** up 3rd gear that needs to be babied to go in at WOT.
What sucks is that I traded in my 07 Civic si for the same ******* issue. Not saying I'm trading in my MS3 any time soon but damn...
no no no, the si actually does have a design issue. i have one of those too ('o7 si sedan) and that problem is being addressed via a TSB that was issued this weekend - http://www.tleone.com/A08-020.pdf
the ms3 doesn't have an issue, it's really a user adjustment issue. i don't baby mine at all going into third, i just adjusted to the car. like i said, i was suffering from the same issue, but after personal adjustments, stuff that has nothing to do with changes to the car, i got it to work beautifully for me. my 2 to 3 shift is straight, pure butter each time, every time. you have to sit down and think more about the shift and what you are actually doing and as you get it, it'll become second nature.
you didn't read what i said at all. you are suffered EXACTLY what i suffered from, and at the same time. remember, i said it was a problem when i first got the car (like you). i had issues shifting into 3rd during "racing" conditions (like you). the first month or so made me think there was an issue, until i made the necessary personal timing adjustments, based on what i described about what i think is going on from an engineering standpoint with the cables and the transmission actuation. the parts i bought might make it easier to adjust to the whole situation (inserts/bushings/SS), i can't say that isn't true, but whatever the case, i was like you and now i'm not because i adjusted accordingly. i dunno what else to say, but i wish you all luck. if anything, the trans and the clutch are tricky to some, but not broken ; )
