245/40/18's + RX8 wheels
Frankly I'd like to know how big of an improvement 235 will make vs 225. Sure it can help in the corners, but by how much?
The lower sidewall height will improve cornering ability too, but at the expense of ride quality and poor-weather traction.
I'm still disappointed that Mazda went for such narrow tires on the Speed3 though.
do the ms3 tpms work with the rx8 wheel or is some sort of modification needed? I spoke with one member and he said the wheels require some milling to fit the ms3 tpms.
Then the consensus here seems to be that RX-8 wheels + RX-8 tires (225/45R18) fits fine. It's when you start getting wider tires or shrinking the sidewalls that it's "at your own risk".
From what I see on Tire Rack, there's plenty of choices in that tire size. My biggest problem is that no one makes winter tires to fit the stock 215/45R18 tires. I'm thinking I may just buy a cheap set of 17" wheels and get dedicated snow tires for those.
honestly, getting the separate set is a WAY better decision in almost all ways. it actually costs less in the long run (no need to mount/remount 2x a year). i got my set for 850ish, and it makes life a lot easier. just be careful what rims you get, though, since the cheaper ones can bend very easily. i learned that lesson the hard way with Sport Edition F7's...=/
Shouldnt be a problem, I dont know for sure yet though. I dont see why they wouldnt work?(scratch)
245's
I have 245/18 on my 8 w/ 43+ offset and its also dropped 1.5" (teins) no rubbing problems for me. just put new rubber on them actually Goodyear Eagle F1 245/40/18.
ill tell you one thing tho, there is NO room for anything bigger in there i can not fit a finger anywhere around the tire...but there is no rubbing at all (1yr of driving) and plenty of nasty bump and pot holes. The car actually will scrape off a cross member before any rubbing.
The front tires however would probably rub when you went knock to knock, but i just put stock size up front.
I have camber issues withe front since its dropped? any one know where i can get plates?
I was told that 225's were the widest you could go on the speed 3 without any issues. WHo's lying?
I think I'm going with 225 40 18's. Would it be so much better if I went with 235's?
i was looking into going with an 18x8 tenzo wheel, so my question is: what tire size and offset would be optimal? i definitely plan on lowering the car, at least on h&r springs, maybe even eibach sportlines. oh, and rolling the fenders is not a problem at all. thank you
I just installed 225/40/18 on my RX-8 wheels... I really wanted the 235/40/18, but was uncertain about rubbing issues. Seems like some people rub, others don't; I didn't want to chance it...
After looking at these tires installed on the rims, I should have gone with the 235s... The inner edge of the rim protrudes farther than the tires...there is plenty of room for the 235s.
I went with Kumho MXs which generally run slightly wider than the other brands. They look great, but 235 would have been perfectly square and taken up the whole width of the rim.
My next size on these wheels will be 235...
235/45 will rub, 235/40 won't....because it's actually shorter in height than Stock...
You Should've went with 235/40s....
I'm running with 235/40s. They're fine.
Another member just posted conditions for every size, if anyone would read, it's calculated to fit fine.
I just don't understand why the whole 235/45 or 40 issue is still around...
Im thinking about 235 tire when I will have to change them i have stockers now on 18x8 38mm offset and i know i will rub iwth bigger tire
Actually, I'm wondering if 235/40 will be wide enough on a 8" rim to make it perfectly square...seems like 245/40 wouldn't be better...
I'll try the 235/40s when these tires wear out...then might try the 245/40.
235's vs 245's
The new 08 Audi A4 Cab with upgraded wheels uses an 18x8 rim with a 235/40-18 tire (Potenza R050a) - looks and fits perfect. I plan on getting that size in a Falken Aziena RT615 after the stockers were out on my RX-8 rims.
The 245 on a lowered car can rub from the post I have read. Not sure I want to roll the fenders.
Should look cool and handle a little better.
Cheers!
Peter
This is a good thread though I'd like to see more folks post what type of tire they're using.
Maybe there could be a sticky or official "These will fit w/o rolling" thread, where people can simply post Wheel size, offset, tire brand and size, suspenion and if they had to roll fenders or not.
When the WRX wagons started getting really popular, there were a lot of threads on various Subaru sites with topics just like this until someone finally compiled all the data into one thread titled something like "THe Official Wheels and tires that will fit the Wagon" thread.
Bump! So no one has experienced rubbing with 235/40/r18 on rx8 wheels with stock suspension?
I have no issues with the OEM TPMS sensors fitting the wheel and working with the ECU. It was a bit of a problem finding grommets that fit. I'm running 225/45s on mine with no contact issues. I suspect I could go to 235/45, but it'll be a long time before I need to address that. I expect these Yokohamas to last five years or so.
