good luck !! there is like ZERO room to run those vacuum hoses through the fire wall. you will need to drill some holes to run vacuum line in and back out of. too much of a PITA if you ask me.
does the turbosmart in cabin controller actually run pressurized lines through the firewall? You aren't going to get very accurate adjustments with hoses of that length, you want them short as possible.
Check out the HALLMAN in cabin controller-- it just extends the knob, not the tubes.
