Gauge vs OBD-II - who to believe?
khoney
'87 RX-7 TII, '04 RX-8, '07 MS3, '14 6, '18 CX-9 Sig., '25 CX-70 STP+
I recently purchased an OBD-II scanner (contains the ELM327 universal protocol converter), and am working on a custom interface to it. Today I noticed that my tach and speedo are off from the OBD-II reported values. The tach gauge is about 250RPM higher than the scanner at 4500RPM, and the speedo gauge is about 4MPH higher than the scanner at 70MPH. I have OEM tires and rims. So, which should I believe? I don't have a radar dector - so can I drive faster now? ;)
Also, are we unable to monitor O2 sensor data on the MS3? The scanner is always reporting that a full drive cycle is incomplete or the vehicle does not support O2 monitoring. This is even after I drive it 25 miles.
On my dashhawk I can read my air to fuel ratios and stuff like that, maybe yours just doesnt support it with the mazda?
It sounds like what you have is more universal not like the dashhawk/scanguage that are vehicle specific for the MS3 so that may have something to do with why your readings are off and not working at all.
beleive the gauge, it was designed, built and installed by mazda, your scan gauge wasnt.
There's no question that the scanner is reporting what the ECU is seeing - that's the whole purpose of OBDII - it's a standard protocol, so the scan gauge has nothing to do with it. I guess the question I'm asking is whether the needle gauge is a more true representation of actual speed/RPM than the sensors that are reporting to the ECU.
"Universal" simply means it can handle different physical protocols, such as PWM, CAN, VPW, KWP2000. The data is the data, and is defined by OBD-II standard. The data is the same regardless of the protocol. "Vehicle-specific" scanners are able to read additional parameters beyond what is defined by the OBD-II standard, e.g. transmission, BCM, ABS, etc.
I can read AFR and Lambda on my Aeroforce, I currently have it set up to read AFR and Boost in PSI with the shift light set to go off above 6k rpm.
What differential are you seeing between the scangauge and your needle gauge? Because the scangauge reads directly from the ECU.
Factory gauges are hardly ever exact. I would believe the scanner for actual data over the factory gauges.
I think it was 2 years ago that Yamaha was advertising that their new 600 had a redline of 17.5k, which is what the tach was showing, but if you actually measured it, it was only 16k. Forced them to issue a refund of the entire motorcycle to anyone who complained.
Lesson learned; measured (OBD) > indicated (needle gauge)
It goes for the speedo too.
your gauges are analog, the scanner is digital.
the error is occuring when the signal is converted from 0s and 1s to making a needle point at something. it's the exact same signal going to the OBDII port and the gauges. it's just being interpreted more accurately by the scanner.
The gauges in the instrument cluster are essentially using the same data that you are reading from the diagnostic port because the instrument cluster is connected to the same CAN bus. If there is any discrepancy, it is the gauges that are wrong.
It is common for a speedometer to read high. For obvious reasons, speedometers never read low unless something is wrong.
your stock gauges are off. it is very common. the scanner is the actual number. the scanner sees what the ECU sees it just displays the info. OBDII is a universal system and the scanners act like TV screens, thats all. they dont make up the numbers or do any conversions or anything like that. it displays what is going on. stock gauges are often off. my DH reads different from my tach and speedo too. the DH is correct. the DH reads directly from thee coils to measure RPM it cant be wrong. the stock set-up loses some accuracy along the way somewhere. it is a needle style gauge, there is a lot of points that can throw them off. i remember i put a shift light on my old mustang back in the day. i set it for 6k. my dash tach would read only 5700RPM when the light would flash. but it was the light that was correct.
If a scan tool is reading speed in MPH, a conversion from km/h to MPH is being done.
true but it still based off what the cars sensors are telling it. it isnt just making up numbers. the MPH/kilometer conversion is just a display option. the scanner isnt decoding signals from the cars sensors.
I can tell you that the OBDII RPM display is not perfect. If you do an acceleration run and log the RPM, then graph it, you can see that it has regular flat spots. I believe this is some kind of arithmetic artifact that allows round-off errors to effect the data. It drives the inertial "dyno" calculation of packages like Auterra Dyno-scan banannas.
