need help (brake problem)
LostSoulx316
Contributor
2003 Protege5
ok well i was driving home from work last night and i start to notice like a pulsing in my brakes when i hit them but then today it was worse it felt like i was driving with my ebrake up but its not the rear brakes its the front and i dont know why this is happening it like they are stuck braking. so if anyone could help please let me know. i was thinking warped rotors maybe ??
your rotors are warped. i have gone thru this with almost every car i have ever owned, (i'm hard on brakes) perfect opp. for some cross drilled!
ok cool
ya i was thinking about that but i like the slotted ones better the holes on drilled get filled to easily i think but i could be wrong
Technical term is lateral runout. Happens to all rotors eventually. Use this opportunity to get some quality ones, and some SS brake lines while you've got the calipers off.
Horsepowerfreaks used to be a vendor here. I've ordered a lot of stuff from them in the past. They're good also.
before you go and drop a couple hundred on new rotors, there's a solid chance that it's just uneven pad buildup on the rotor. Get some fine grit sandpaper, steel wool, scotch brite, whatever, and give them a good rub down with brake parts cleaner. See if you can clean up the pads as well. If it fixes the problem, you've saved a lot of money ;)
well now my front brakes are done they were smoking like a b**** last night so i cant drive my car anymore cause i dont want that to happen again so ya :(. i hered that it was my caliper that ceased up but when they cool down they let go and i can drive it again i dont under stand anyone no what it could be now lol
