mrlilguy's vs cp-e fuel pump?
yes and no he his motor is shot but then agin it was dont by a mistake (mrlittleguy sorry for speaking on your behalf) when he miss shifted and come on now we are human beings we make mistakes i can afford a turbo i cant afford an new motor but that and a good tunning salution is all i need
millgruy motor blown??
dude did his motor really blow...??? come on tell us..(sssh)..lol
i just double tapped it yes his motor is shot it was written in another thread dont ask whitch one but i talk to later about it thats kinda how i knew
i wried mine in like 10 months ago works fine! no isuues, the wires look kinda cool too, it gives your engine bay the "this is serious" look..lol
wait hold up let me get this put out first i am currently in iraq i will be home in less then a month all the parts i stated i had i own already. there already at my house along with other stuff for the car wheels/speaker ect.. i am going to have a big build with some buds of mine when the first weekend after i get my car out of gov storage and i am simply wontting to purches this fuel pump in prep for going big
well from the data i have seen.....
mrlilguys pump has proven to flow 52% over stock while cp-e's stuff flows only 40%. and those numbers are directly from the company who makes the internal parts for the pumps. also from the datalogs i have sens from both. the mrlilguy pumps seem to make peak pressures over 2000psi and maintain 1700+psi for up to 500HP. from the cp-e pump logs i have seen from member dadasracecar that pump never comes close to 2000psi. it hangs right around 1650-1800 from what i see. and keep in mind that car is only @18psi.
MRLILGUY FTW !! mine ships out next week from him. who hooooo !
The mrlilguy pump has not been proven to flow anything. They are not tested on a flow bench tester so there is no way to know. He tests(ed) them on his car before sending them out, though that will be difficult now. The autotech parts that are used in a VW pump apparently have been tested to flow 50% better than stock. THe cp-e pumps are tested at APR and have been proven to flow 42% better than stock.
The pressure observed from datalogs has no bearing on the flow of the pump. Stock rail pressure is supposed to be 1600-1800 psi. It's only a problem if the pressure is below that. My fuel pressure stayed in the 1800 range during a 1st-5th WOT run at 18 psi on my full bolt on car.
I wonder how the lilguy pump has held pressure to 500hp when no actual MS3/6 has even come close to that number? Where are these datalogs?
Here's a couple from the other day with my boost set at 17 psi.
4th gear
