s***!! This car really falls on it's face at 6000RPMs!!! It's a dead day over here for me with the wife out and the temps in the low 40s. I was bored and took the Speed out for some "spirited driving". While looking at my tach watching for the red light of the shift light to flash I noticed that my 5500RPM setting on the light was pretty dead on with the Tach. I figured that 5500RPM setting to be a little low. I started raising it by 100RPMs until I was around 5900RPMs. The car felt best at a setting of 5700RPMs on the light and me shifting quick but not trying to be the FLASH at it. With the light at 5700RPMs I always got through the shift in all gears (well...2-6 I didn't try the 1-2 *YET*) before the stock Tach hit 6000RPMs. I took the car past 6000rpms for s**** and giggles for the 1st time since I have owned it. It has over 5000 miles on it now so I figured what the hell. Man, as soon as she hits 6100RPMs the boost falls real fast to 10PSi and under and the power **DIES**!! Do the cams in this car really have that short of a power band or is the stock top mount intercooler really that restrictive in the upper RPM band?????? My boost with the Cobb SRI and the Forge BPV hold ROCK steady to just under 6000RPMs and then it's like all HELL breaks loose and the boost and the car s**** itself! The other strange thing is the more I romped on the car the more powerfull it felt?
I guess my point is...........Guys with the ETS 3"-3.5" top mounts.......are you holding boost longer in the upper RPM range? What about front mounts? I was/am looking at the Corksport unit.
OK that's all..........little bored.
