Just installed Cobb Rear Sway and had a question
Tagkat
2008 Mazdaspeed 3
My left end link is bent slightly like a knee where the right one is straight. I double checked the bushings and made sure everything was tight and ideas?
Thanks!
get new endlink?
how'd you like the cobb set up? I've been thinking about them too. not bad for 600 with spring, f/r sway.
The cobb sway only has issues with the front sway. But they are redesigning it. I think the springs and rear sway greatly improves the handling characteristics. The End link is supposed to bend just not sure if it matters since one is bent the other not.
Waiting for it to warm up here, the sway I think is worth it car stays more flat.
And it's a simple installation.
I thought Cobb had fitment issues...?
Do you have the specs (diameter) on the Cobb bars?
fitment issue was only on the front, and it's only if the suspension is unloaded. You have to tighten everything up with the suspension loaded - either ramps or 4 post lift
Good question I'm assuming the attachment points are not lining up well. Call Cobb, there might be a trick to this angle of the axles or sumthin. or you have a bad part. Go to the source on this one Tag
