Headlight assembly
It's a small bulb size, but it's meant to provide light to the housing when the parking lights are on. When your halogen/hids are on, you won't be able to see the light output by the tiny bulb.
that socket isnt near the area of te whole
anybody got theres yet?
yes it is. if you look reeaal close to the back side picture, you'll see that the housing is flipped upside down
EDIT - i took my own advice, and looked again. maybe it isn't? i'd like to see the real thing too.
neither do mine, and i even passed the state safety inspection with 'em. just make sure you put a yellow / amber bulb in there.
Mine came today. I ordered some silver/amber turn bulbs and a silver/white daylight running bulbs to go in it. Does anyone know where I can get the square power connector that is meant for the daylight bulbs? Looks like it's a default mazda 4 pin connector (where only two pins are used).
So that thing nik was reffering to is the plug for the little light inside the main headlight? u probly just have to figure out which is pos and neg ad run some wires tapped from the side lbinker into it coming from under the headlight to keep it clean.
post some pictures
First picture is the rear of the headlight. You can see the wires leading to the 194 size connector. Those wires go into the front of that black square that has two pins. I've seen this kind of connector before, so I'm wondering if Ken can get one.
Second picture is another rear shot. Note the locking ring that is above the light on the floor.
Last picture is from the front. I did not remove the protective plastic so I don't scratch the hell out of them when I actually install them. At first glance, it appears that the corners could be swapped for other stock corners, but I didn't not test fit any.
The blacked out sections are the color of the plastic and not paint. On the top it appears that there are two plastic aiming screws.
Those look really nice. I don't think mine has shipped yet. And wouldn't it look a litte weird without the reflective diamond on the corner lights and just the bulb?
It looks like it on the far right that it does in the pic. The seller has missed one day on shipping mines too. how many days uve been w8ing?
I've been waiting since the 7th. He hasn't responded to my email yet either. And I hope that corner light has a reflector.
s***...he responded fast to the ?s i had.
i was tryin to get them for spring break.
Haha me too. Actually I just checked my email and he finally responded. He said he shipped them out today, hopefully it won't take too long now.
