If u think about the flow, picture it flowing like water.
That volume of air will inevitably feed the 1st, 2nd and 3rd velocity stacks before reaching the 4th. You dont want to risk starving that last cylinder's air flow!
I think the angle deflects the flow and induces an additional vortex near the end of the chamber, ensuring plenty of available air flow.
(whip)
I love those stax! (godown)(godown)(godown)
Spot on... in addition to that, the plenum roof is tapered slightly over the entire length to help feed the further cylinders. It doesn't have to be much, but it is there.
Lookin' good.
Man, that head flange is super thick.
Is that going to be machined to accept the injectors and will there be bosses for the stock fuel rail?
The flange will be flycut after welding. It is 3/4" thick right now, but will get machined down to the stock thickness of 1/2". We want to make sure it is perfectly flat to seal up properly on the motor, and any bit of warping from the welding will be dealt with when we machine it down.
And of course there are going to be injectors in the flange... if there wasn't, the car wouldn't really be going anywhere.
Injector bungs are machined in last, after assembly? Looks great BTW
Thanks bud. Yes, the injector holes will be done last, because they are so close to the runner/flange junction that if we did them before welding, they would get lopsided and the injectors wouldn't seal right. After everything is welded up, we're machining those into the flange.
Just wondering about the flow on this thing....are you confident all runners will flow equally or close? Just asking...not sure what the science behind all this is but to me...it looks like cylinder 4 has a sharp turn.
Yes I am very confident that they will flow equally after seeing this thing on the 3D computer flow software. Between the slight taper across the entire plenum, and the angled end cap, the flow will be perfect.
Looks great. Good call on perfecting the floor area and air horns. Much nicer piece because of it. It may take longer, but it is so obvious when somebody takes the time to put out a quality product. Cheers.
Thanks man, yeah I am real happy with the new velocity stacks. That is how they were designed to be, and it only took one tiny little miscalculation when Kelly and I were inputting the data into the CNC software. We needed to double the radius to get our thickness, and we overlooked that and put it in as half the needed value. That tiny mistake made those pointy stacks that you can see on the first plate, and it is nice to see them how they were supposed to be.
you should sell it like it is, duct tape/cardboard runners n all. i'm sure it would have most excellent gains lolz
I will sell you a FULL tape/cardboard version if you would like, just don't run very much boost on it please.
