Awesome Motorsports Pictures & Videos
Damn, the Smiths' and Heyward's Civics get around. I didn't realize that you drove it too. They must have each had half a dozen people drive them.
That was Brian Bell's car. Notice the black, not orange, numbers.
Heyward's car won $1000 in contingency money at the Dixie Tour.
Didn't know he had picked one up as well.
So that should cover the set of tires they must go through every couple of events.
Here is one from this weekend:
NICE tripod action! What tires are you running?
Falcon Azenus RT-615 205x7x16 mounted on Rota Slipstreams.
I made the mistake of installing the MSP Front Swaybar when I first started Autocross. Now that I know better, I disconnected it and these pics are the result. I''m going to try no sway bar couple more times to see If I'm truely faster. My feeling is I'll have to put the stock bar back in, but being the fronts bar is a b**** to install, I'm procrastinating putting it back in.
Nice S2000 pic.
Did you put that pic through a filter or are those really Heat Waves?
Nope, no filter. It was shot at about 200 yards with 300mm focal length and then cropped.
The heat waves are real. I think it's the best pic I took this past weekend.
Unless you are running really high spring rates you need the sway bar to counter roll.
yeah, I have learned alot in the past 8 months. Due to my ignorance, I installed the MSP Front Sway bar and AWR 21mm Rear. Running 350 GC front / 250 GC Rear on Tokico Blues. I wanted to see if softening the front sway would be the correct direction. I'm thinking since the front is stiffer then the rear, it will not be that big of a problem. I'm only go to try this out a couple of events to get driving experience on How the car feels with different setups. Then I'll put the stock front sway in keeping the 21mm rear, alone with K-Sport 350 Front and 500 Rear. I may in the future, then keep the sways the same but go up to 450 front and 600 rear. But that is along ways off.
