AutoXRacer
I little off topic, but what does race gas do for you on the stock maps...?
I dont know why everyone is getting their panties in a bunch over the ******* rods. Its this simple, rods will go through the block when you get detonation. These are DI, have a higher lean rate and there isnt one single problem the MS3 has experience that the MS6 has. So **** it, time to prove the naysayers wrong. If a Lightning can hold 500hp all day long at the wheels with a big ass Kenne Bell blower and tune with its sorry ass weak rods, this engine isnt going to have a problem. As long as you got that MRLILGUY fuel pump and keep this boost below 20 on that monster, you guys are going to hit 400hp with little effort. For those who are ultimately paranoid, add some methanol.
The drivetrain on the other hand, is going to be your weak point. Get a beefy clutch and go easy on the trans from gears 1-2 & 3. From what ive seen of the internals on this trans, the synchros look quite weak from 1-3, but get beefier from 4-6.
Lets him crank the boost up.
race gas is higher octane (110) and is much less likely to detonate -
So if you run stock boost and have no adjustability in tuning (stock ECU)...race gas is useless...
Basically, the stock ECU will not take advantage of the higher octane gas...right?
Correct, and your bearing's will thank you.
Sweet, another race gas discussion. And I'm not being sarcastic there, I really do like race gas discussions, lol. I dunno why. maybe the same reason I like red heads over blondes, and LOVE red heads over blondes.
Sans tuning, race gas won't do anything for you. Its too bad most people don't know that. I've run into people who claim with stock 15 second cars they've been able to run 13s on 110 octane, lol.
I was always told by my tuner (Jorge from P&L) that running race gas ona pump gas map will not net you any more HP and it will take a toll on your bearings. He said something to the fact that race gas and pump gas burn at different rates and running race gas on a pump gas map will result in your bearing's getting pounded. I dont know how to explain it very well, but they way he explained it made sence.
Jorge is a pretty smart guy. I would listen to what he says, now on that note mixing race gas and regular together for a few runs down the track isn't going to do anything harmful to your engine. P&L is where we took Jason's car to tune it.
I know of only one MS3 with a bown motor and that was a manufacturing defect. It's funny how you make a statement like that on your First Post.
im not saying it will increase HP!
im saying it helps make for cooler combustion and less detonation which is always better IMO..... The HP comes from the ability to run more boost due to the higher octane.
Race gas net's in HP due to the fact that your able to run higher boost due to the octane jump having some sense that detonation will hold off due to the cooler burn (not always ofcourse).
