alrighty, the long awaited update (2 days).
i got to tulsa and put the car on jack stands pretty quickly, and went ahead and handled all of my mod installs. the new trz motor mount is excellent (delrin bushing), and the turboXS racepipe fit perfectly. kevin (a friend from school who's 'rents live in tulsa) helped out, and without him, the meth injection install wouldn't have turned out so great, nor would the test pipe install - that was definately a 2 man job.
on to the real fun: we went out friday night and the car sounded and felt WONDERFUL behind the wheel. between palerider's pump (heheheheh), the intake, boost controller, test pipe, and new motor mount, the car was truly a new machine. we went out on some back roads for some butt dyno runs, the car was definitely feeling significantly faster, even without the meth injection (i'll explain in a bit). soon we were down in mexico and met up with a friend who has one of the fastest srt4's around. very quick machine, and his 4th gear was dominating. he's at least 330whp or so, at 2900lbs with him in it.... full boltons, biggest fmic i've ever seen, 3" dump tube, custom tune, intake, you name it. he was pushing close to 22psi on the td04.
next morning was dyno time. loaded up the car with misc tools for parts swapping (intake, pump, etc) and went up to VDP for a good time.
I got strapped in at 3pm and was there until 520 or so. great shop, great guys, great rates, I couldn't have asked for anything better! they had a dynojet dyno using the winpep7 software. I was excited because this was the exact machine I dyno'd on back in dallas, stock car put down 245/270 in 4th gear. at 19psi a few months later with the ATP boost cut killer module:
264/332 at 4250rpm, because fuel cut and spark blow out came into play. this is what that stuff looks like on a dyno:
so, as stated, kev and I got on the dyno and went to work. we started out at stock boost levels, stock airbox, no methanol injection, and the modified hiflow pump, and worked our way to fully modified with the pump upgrade and higher boost (20psi falling to about 16-17psi in 3rd gear), and then swapped pumps at the 17th pull to be at fully modified at pull 17, then back down to stock boost levels nearing the 28 or 29th pull.
the following charts give you an idea of the results. there were about 30 pulls on the dyno, varying in 3rd gear, 4th gear, and 5th gear at the end for kicks, just to see what would throw down. as I already posted, the dyno was reading extremely low. I was very frustrated (kevin can vouge for this, i'm sure I snapped at him a few times, sorry buuuuuddayyyy! (second) ) You've seen the charts at stock and 18psi, and look what I put down with a real intake (short ram intake, with a cone filter) and the test pipe, as well as the water/meth injection and pump upgrade. i've compiled a list of dyno graphs, showing very consistant data between runs that were with the same mods, yet different fuel pumps, one stock and one modified.
some of the graphs i threw out because of sputter or methanol injection, the meth injection yeilded no gains, we actually lost a few ponies in being too rich. everynow and then i would throw on the there was no way to tune in the timing that we wanted to get back with the colder burn (H20 evaporation and methanol acting as a fuel to raise octane). do recall that we're on stock ecu, no other management other than a JoeP manual boost controller (still love it). so, in turn, don't go invest in methanol injection without a better way to tune the ECU, whether it be a xede, accessport, or standback unit. the ONLY reason i bought the meth injection and installed it at this point is because 1: i'm impatient, and 2: I paid $160 for a brand new devilsown kit shipped, including the progressive controller.
onto the graphs: look at the numbers of the run files and the title of the graphs to see what mods are what at what time. I COULDN'T care less about the numbers, being that the peak numbers at the given point in time with the different mods are pretty much the same (with 10points of eachother), but what I am interested in, as should you guys, is
the a/f ratio curves, after all, these dyno's were done to see how the ECU and pump(s) react together with different supporting mods. you can see the leaner midrange with all of the stock pump graphs, vs the the little bit richer midrange. Look at the power/torque curves too, they show more power at any given time, other than peak. the curves are more full and round, resulting in more torque, or 'throw you back in your comfy highbolstered mazdaspeed 3/6 seat' feeling. also more hp, but mainly torque. its nice to see this stuff on paper.
blue lines are always hiflow pump, the red lines are always stocker (other than iced intercooler graphs)
testpipe:
Short ram intake and testpipe:
Short ram intake, testpipe and 18psi in 3rd gear (falls to 16psi):
Short ram intake, testpipe and 19psi in 3rd gear (falls to 16psi):
Short ram intake, testpipe, 19psi, and iced intercooler:
Best A/F Line:
Best Numbers/Worst Numbers:
also, as we all know, the main reason for the fuel pump upgrade is allowing to flow more power at any given point with supporting mods, and further eliminating fuel cut based on substantial pressure drop from the stock pump. I dyno'd on Randy's (palerider here at mazdas247) PG pump upgrade, and used my core as a stocker, for a quick exchange on the dyno (less than 10 minutes). driving away from the dyno, i was on a stock pump (randy's pump goes out tomorrow morning, he'll have it tuesday afternoon, sleeping with it and his wife on tuesday night, and hopefully installed on wednesday). on my 90mile trek back to stillwater from tulsa, I 'got on it' a few times, and felt the LACK of power with all of my new goodies in the mid to upper range. it sucks. I called randy right afterwards laughing at him, telling him I understand his pain while he doesnt have a hiflow pump.
i hope these dyno graphs are somewhat helpful to you guys. I'll have more data tomorrow evening hopefully, if my schedule isn't too swamped. enjoy reading this stuff guys. any questions, please direct them to my PM box and I'll get back to you later on in the evening. I have to go and meet with my apartment manager now...
