Broken 3rd gear x 3
so... whens the install then dana?
this something you going to be doing over time or looking to slap together asap? I definately wanna make it up in the next 2-3 weeks so lmk whats up.
The gearshafts are assembled at this point, hoping to install the trans over the weekend.
PAR gears FTW...
I have 3rd and 4th straight cut in my car, stock ratios.
I have the following available
3rd:
Straight cut
Stock ratio
Needle roller bearing
stock synchro setup
Straight cut
Stock ratio
double synchro setup (synchros are an additional $120)
4th:
Straight cut
Stock ratio
stock synchro setup
Straight cut
Stock ratio
PAR gears FTW...
3rd:
Straight cut
Stock ratio
stock synchro setup
Straight cut
Stock ratio
4th:
Straight cut
Stock ratio
stock synchro setup
Straight cut
Stock ratio
whats the prices going to be for each of them?
So, now that they're in the car (I assume you've put some miles on them) how's the noise from the straight cutness?
To me it's not nearly as loud as I expected. When you romp down on it they scream a bit like a supercharger maybe half as loud as romping on it in reverse. 1st gear is definately the loudest. People look at me like HOLYWHATTHE!
