Door lube
Rocket
Anyone know the lube points for the doors? Especially the sliders? Any special lube required? Thanks!
Don't follow my ill advice if you want OEM, but I've been using Lubrimatic white lithium grease (Spray and Paste) since got my car in 2005 (especially because it is great on low temps). I have also used it in garage doors and with my older cars in the past.
As a side note, I have not had frozen slide door locks with that grease. I'm not sure if it is related, but no issues so far. I did not perform that recall (decided to not fix what was not broken for that case ;))
