pooping!
(dunno)
pooping!
Nice find Driver and a s*** ton of work finding it...
on stock boost the car ran fine. it was when I turned up the boost that it started cutting out. Blowing out spark. this fixed that.
I am quite sure they aren't the same as the Ford ones. They have a built in igniter. There is power, ground, and a logic signal going to the "coil" to make them fire.My experience with COP ( Coil On Plugs ) quality is hit or miss on them. This is the first time ive seen the contact problem though. Im wondering if these are the same used on the Ford 4.6 and 5.4. Ill check when i get home. If they are, we can run better aftermarket coils
Mazda specs should be similar to these:
Primary Resistance: 0. .660 ohms
Coil Internal Construction: Epoxy
Turns Ratio: 61:1
Secondary Resistance: 6.1K ohms
