shane02pro5
25ish_psi
- New Caney TX
So Mazda specifically calls out Iridium plugs? I have always read that Iridium plugs were bad for turbo engines due to getting hotspots and causing pre-ignition!?
i ordered a set of one stg colder plugs. Ill let you guys know how they feel once I put them in a drive a few days.
I dont think they will fix that. I just wanted make sure the car still ran right and no spark blow out or anything.
What plugs did you go with?
Also, I'm dynoing my car on the 26th and was thinking about a BCD and MBC combo, set to 17psi. Given what I already have done to my car what's your take/how safe is it?
What are your temps where you live right now?
Today it's 60 degrees (extremely rare) but, it's going to drop back down into the 30's and 40's (normal temps). I'm beginning to think that my issue is weather related because I have not had experienced it for the last 3 days, temps have been around 65-70.
What BCD and MBC are you using?
Any issues to speak of?
I've had the 1 stg colder plugs in for over 6 months and have set them at 2 different gaps
studdering is still present
the colder plug isn;t a bad idea when heavy modding but I can assure you they are not the studdering cure
i put them in and car is running bitchen!!
So which ones did you install? did you go with copper?
Stuttering and sputtering are different than hesitation from fuel pressure drop. I had both of these problems and the stuttering/sputtering went away after i replaced the stock spark plugs. Two were cracked. I still have the hesitation from fuel pressure drops.
BTW, these spark plugs are not cheap and definitely not $10-$15 dollars each. I paid $85 for a set of 4 from the dealer and that was with a valued customer discount.
