From that statment, I am gathering that the answer to everyones' question is, YES. The KL is a direct swap with the FS.
Hello, What you need for a complete swap of KLZE in your protege is:
the engine KLZE
trany from the original KLZE or a trany of 626 93-97
you gonna need complete axle of the 626 right & left 93-97
normally we put a new distributor $450.00
the wiring harness of the KL
wiring diagram of the protege
Radiator of 626
thats it
Hi,
I have a complete list in french, I won't translate it, but I'll give you a good idea of what you need.
- Complete V6 engine and transmission with the half-shaft(or joint shaft?) plus uncut wiring harness, ECU and VAF(airflow sensor)
- Radiator and piping, either a MX-6 one or our custom aluminium V6 radiator for Protege(made by Ron Davis). If you use a MX-6 rad, you'll need to make some brackets. Our V6 rad fit bolt-on.
Everything fits bolt-on, you'll need to adapt the wiring to the dash harness and fuse box. You'll also need to adapt fuel line and exhaust. It's all pretty easy.
Two things won't work or do strange things, the tach and the temp gauge, so get after-market ones.
ooo i see. well every1 should start making their swaps so i can admire this awesome accomplishment xD
i'm sure the turbo guys will be jealous hehe
Transmission case is different. Internals are the same IIRC....... so it may be a diffferent bolt pattern.
If Im doing a complete rebuild of the engine, mileage really isnt a concern right?
