uh huh. And I bought my PNP stand alone LAST March. When they were originally supposed to be released.
Isn't that concerning a wait for a custom connector? Not an issue with Cobb. I don't see how the two are related.
Could be an appropriate drug to control the Cobb Mania going on...
CP-E were supposed to release their PnP in Feb what happened? The good news is that we might not need a pump upgrade if we are sticking around 320whp or so as apparently the stock fuel pumps are more than adequate.
The CP-E standback is sophisticated enough to be useful to control the high pressure fuel pump. Their electrical engineer worked on a MS6 project last summer,for a few days, and he later popped out a Standback that can control the high pressure fuel pump output.So combine it with throttle controll and boost pressure,you`ll basically have no need for a turbo upgrade,unless you`re looking at 400hp+.(drive2)(bowdown)
false, the car will cut out, fuel cut, run out of fuel if you see 18psi and cold weather.
You don't know what you're talking about. What do you do, scan the forums for anything pro cp-e and try to s*** all over them? My car works like a charm. No fuel cut whatsoever. I run 18 psi all day.
That's 280 awhp. [rice math] factor 20% for drivetrain losses and that's in the 320s.[/rice math] Of course we don't know what you car makes b/c there's no dyno. wanna run 'em?
Where's "down?" I'd like for you to be the first MS3 that I've raced/owned...ill run ya... bring it on down.. just because i dont list all my mods, doesnt mean you have a chance... you wouldnt be the first MS6 ive owned, ill tell you that much.
