Cp-e Standback or Cobb Accessport
CP-E were supposed to release their PnP in Feb what happened? The good news is that we might not need a pump upgrade if we are sticking around 320whp or so as apparently the stock fuel pumps are more than adequate.
The CP-E standback is sophisticated enough to be useful to control the high pressure fuel pump. Their electrical engineer worked on a MS6 project last summer,for a few days, and he later popped out a Standback that can control the high pressure fuel pump output.So combine it with throttle controll and boost pressure,you`ll basically have no need for a turbo upgrade,unless you`re looking at 400hp+.(drive2)(bowdown)
Youre going to need the pump to make safe horsepower. The stock pump is already at its max as is.
false, the car will cut out, fuel cut, run out of fuel if you see 18psi and cold weather.
nig3 couldn't have said it any better
You don't know what you're talking about. What do you do, scan the forums for anything pro cp-e and try to s*** all over them? My car works like a charm. No fuel cut whatsoever. I run 18 psi all day.
ATTENTION ALL CPE NUT SWINGERS
your car also makes a whopping what? 270whp
hear the popping under wot? See the car dying up top? hmmmmmmmmmm
wait, i have mad editing skills and made the video up as well
lol, ouch that hurt. My cars makes more than that (lol)
That's 280 awhp. [rice math] factor 20% for drivetrain losses and that's in the 320s.[/rice math] Of course we don't know what you car makes b/c there's no dyno. wanna run 'em?
dude, if you want to waste you gas and get humiliated on video that will get posted all over these boards, be my guest. Better yet, go to a track, run your low 13 at 104mph then compare your timeslip with mine, oh wait thats bulls*** to. So is the video above your post.
go compare the big turbo ms6's time slip. 12.8 at 106, that car is making 330 AWHP, you know, about 50 more than you
I believe the CPE engineers have determined that the stocj pump is adequate to handle 350hp at crank so im not bothered.You just need the PnP and fine tuned to 93 Octane fuel with CAI,DP,Turbo Manifold combo.
It should be good to go without any fuel cuts up to 320-340hp at crank any more than that i really do not need to be honest.
ill run ya... bring it on down.. just because i dont list all my mods, doesnt mean you have a chance... you wouldnt be the first MS6 ive owned, ill tell you that much.
why not just have a battle of the Speeds in the summer? I'm sure we will be able to give you all a run for your money by then... Some interesting things are happening this spring...
as much as i want the AP, i think i'm gonna give people time to check it out and be the guinea pig for me...:D in the meantime, i will concentrate on mods that will give me best utilization of my AP when i DO get it. like: tires, springs, sways, etc...=d
