if losing low end and gaining all top end power is what some of you guys want, then go for it... your gas mileage will probably suffer too, something that's important to many people as gas prices are expensive anywhere these days
like I said... 99% of us drive our proteges on the street, I still think a usable flat powerband is more practical (and efficient for gas mileage) than anything for a street motor..... but if max power is what you are looking for, then ditch all the stock s***, A/C, and power steering too
you'll be sweating your ass off for a few more hp while I putt around town in the comfort of A/C during summer
since there's those of you who are dead set on getting rid of the VICS intake and using the 626 ones, and those like me who are just happy with what VICS offers, I'm really surprised everyone has quickly forgotten about the japanese/european 626 intake manifolds (which should restore some low end and some power at redline) that I mentioned a while ago in that huge "SU" thread
it's like the 626 s*** we got but it adds a small helmholtz resonator to boost response.... I guess everyone forgot about them because 1) the USDM s*** is easy/cheap to get, 2) no one cares, or 3) everyone are just a flock of sheep who gets what everyone else gets and don't try something different to discover new things
I do think it was cool jamesk got this USDM 626 intake manifold to try though, but I still think there's no findings or discoveries until I see the dynos
the small "helmholtz" resonator is on the aussie 626 manis as well (just pulled one apart at andrew's place)...
Helmholtz can be used for 1 of 2 things. You can tune helmholtz for power, or tune helmholtz to cancel noise. Obvioulsy if by some insane fluke, the point at which power is improved is the same frequency as the noise cancelling, you get both gains.
But this resonator does nothing for power (it infact, would make it go backwards, because in effect it is increasing plenum volume, which will reduce intake velocities and harm low end more).
The mathematics i've given you are part of the equation for working out a resonance tuned intake manifold. The rest of it is in plennum design, and the ram tunnel - essentially making the ENTIRE MANIFOLD AND INTAKE TRACT a resonator. Thats how you make power. Slapping a 750mL plastic chamber on the side of a manifold wont do diddly squat for power.... you're clutching at straws.
The 626 manifold reduces low end response, yes. But it wont reduce it to the point that its detrimental to drivability of fuel economy. Infact, in the midrange, where 90% of your driving is done on the street, it would be highly effecient because of reduced pumping losses and increased volumetric effeciency. This isn't even taking into account other fuel economy improvements gained by other modifications which are usually done to our cars - header (reduces pumping loss, improves VE), exhaust (reduces pumping loss, improves VE), light weight flywheel (reduces rotating mass, improves fuel economy) and so forth....all modifications which mean the engine needs to work less to achieve the same result and thus saves money at the pump. Add management into the mix and even with the 626 manifold you are going to have probably at least a 50% improvement in fuel economy over stock.
EXTREME tuned manifolds (such as the one i'm designing) will hammer the low end and midrange bad, and your argument will be 100% valid on the manifold i'm designing, but economy isn't the goal with my manifold.
No matter what argument you are going to come up with, the SLIGHT improvements in the breadth of the power curve vs the 626 manifold are not enough to counteract the benefits of going to the 626 manifold. The car should have had single runner from the get go. VICS gets the "EPIC FAIL" award... and if you opened your eyes and looked at the numbers that come out of the flow bench, the results of the mathematic calculations, and so forth, you'll see that it is sub par.....
I'm happy to run through all the calculations and theory with you if you wish... not in this thread though, as it isn't an effective way of having a conversation. Perhaps we could tee up an MSN session at some stage, have a discussion, and i'll copy and paste the results of the conversation into this thread for all to read.... you can ask any questions you need to ask, and i can answer them for you, rather then having this conversation draw out over 20 odd pages (which is how it will go if we keep this up!).
I'm more than happy to discuss with you, pm me if interested.
Ta.
