LOL at least it's not a super expensive one (unless you baller up for an HKS Type II that Supras like to run - it's around $350).
BPVs by design are great for stock cars, but I think the whole drive by wire thing screws up the purpose, because as the ECU is fluttering the TB plate going all whacky (esp at WOT in these cars) is allowing the BPV to maybe open just ever so slightly, enough for a little boost to squeak out.
Usually factory BPVs don't fail so fast when upping the boost too. At least most of the metal housing ones don't (1g DSM holds well up to 20psi many times before you have to crush it). I'm wondering if the engineers at Mazda almost didn't purposefully design the stock BPV to start "leaking" after 1-2 psi above the stock amount, as a safeguard. Not that it's gonna thwart someone from throwing on an MBC and trying, but it's another option in the fight against an unexpected overboost from a line coming off or something.
