Muff, while that looks like positive camber, I would be pretty certain that the suspension actually gains negative camber as it cycles up in its travel. It just doesn't gain enough camber to overcome the angle relative to the ground generated by the massive body roll. If you measured against what would be level on the chassis, I'd bet it still gains some negative camber.
