Ok guys I have the inside torn apart to try and fix the crappy install the audio place did...(get hum from engine not only from the AUX input but even from the CD unless I turn the gain on AMP way down)
So I can go and get a filter for the aux input but what about the cd? I guess I could get one for each amp but Im suspecting my problem is with the LOC converter - frigin installer didnt even ground it but after grounding it the noise is still there...
SHould I get another LOC and redo wiring, get a filter? Ive spent the last 2 hrs dicking around with the gain on LOC and amp and Im not sure which is the best method: small gain on LOC and large gain on amp or viceversa - only way I get no hum is to drop the gain on amp but that limits my sound levels to slightly better than stock
This is getting frustrating... any thoughts?
The Line Output Converter is a Axxecc ALOC 648 (what I could find at the time of install)
gonna go take a shower hopefully some of you will bail me out here...no point in upgrading speakers till frigin hum is gone
