Who's Making the most hp on a stock block?
my dyno is at 305whp and no exhaust yet. 17.9 psi
With exhaust you shold definatly make the 310-315 whp range.
Dude can I make a suggestion? Take the fuel cut killer off your car if you are using it in tandem with the standback your gonna blow your motor.(hand)
That thing bleeds off map pressure and will tell the standback that its seeing different boost pressure and it will not make the correct adjustments for timing. If you dont belive me call Ken at the Protege Garage and he will help you understand.
We almost have all the same parts and look dude only yours is red!
Mike if you were tuned for 14psi that means your not supposed to up the boost bro. You probably didnt have enough timing pulled out and BOOM. There you have it.(blowup)
maybe who know i dont care what happend! the thing is that it happend and nog i got to fix it!(hump)
With drivetrain losses considered, you are saying that 329whp (AWD) is more powerful than 394whp (FWD)?
well the 394hp was with methanol injection without it was like 350 so if Jason was not using methanol injection the 329 to 350 is pluasilble
yes it is important to note that BHP is not at all the same as WHP. 400 BHP is still very potent on any car. 100 horsepower per liter? try 100 horsepower per cylinder!
