Is there a way to disable the TPMS? I don't want to spend a few hundred dollars for fancy stems when I get my snow tires with steelies for the winter. I don't see a fuse for it but can I disconnect the module??
take all of them out and put them inside the spare then air it up to 32 psi...cant really use ur spare then tho
I'll confirm the "no beep"; I just bought a set of rims and studs and also did not wish to kick in another $250.is gonna be no beep at all, it will flash for about 2 mins after you turn on your engine then just stay there forever.
You learn to live with the light...
which probably isn't a bad thing...I was going to just put a bit of black electrical tape over that spot, but my wife said no.but I REALLY hate that damn light, always feel my tires are run out of air, so i have to check tire pressure once two or three days.
YEa I kind of like to have the spare for when I get a flat.
The RX8 Sensors are siemens?Toyota/Lexus uses Pacific TPMS. These sensors transmit pressure info intermittently and are not triggered but tire rotation. Apparently 1st gen TPMS in Mercedes (made by Seimens) are the same. All the other Japanese (including Mazda) and domestic manufacturers use Schrader TPMS. This system is a triggered system. That's why installing the sensors in a pressured pipe or container will work for Toyotas but not Mazdas.
