Small update
These cams are sick. I finally installed my intake, hardpipes, and smic, which were my biggest restrictions on the car at this point. Even with the stock ecu, the car pulled amazingly hard all the way to redline. The cams seem to "kick in" around 4k, but they continue to gain power until about 5k. Then at 5.5K, the stock MSP ecu has a timing jump, and the car pulls even harder until redline. Mind you, Im only at stock boost
As a testimony of the power I'm making with these things, at stock boost, with the stock ecu, I did a 3rd gear pull and was dead even with an 07 Legacy GT. Hes a 3" perrin downpipe, perrin UDP, and borla catback. For those of you who don't know, the Legacy GT is pretty much a detuned STI. His mods put him right around stock STI power/speed. Remember, this is on the stock ecu (running super rich) and at stock boost!
I installed my AFC V2 last night, and the stock super map just doesn't give enough fuel for these cams. By 5k, I am running 12.8 AFR, so i get off the gas. I need to adjust the maps and then hit the Dyno. More to come!
Guys, If you haven't already, hurry up and get these damn things installed ASAP. You
won't be disappointed.
