Will they g35 wills fit on the ms6?
The wheels on the G35 will not fit for 2 reasons.
They have a center bore of 66mm, ours is 67 so depending on the tolerance you could make that work or bore it out a little bit.
Second and most importantly the G35 and 350Z wheels come with a +30 or +33 offset, and average 8" wide. There are some 7.5" and 9" wheels that are available from the factory.
http://www.350z-tech.com/zwiki/350Z_OEM_Wheel_Specifications
like stated above with some custom work it would fit and id love to see that done +1 for creative thinking
I'm sure you could cut the offset of the wheel done to at least a +38 or so, I've seen it done with other wheels but each wheel is different.
