mazda 3 amp/subs instalation
vlrussian
Banned
hi everyone i just bought yesterday mazda3 08 and i wana put my subs and amp and i wana know what i need to do it and how, ill appreciate details to how removing and running wiring and all that stuff.....
thank u to all
Maybe eventually a mod actually sticky one of the 100000 sub/amp install threads on here. Any-hoo here is the thread I used while doing my install. Has pretty much everything from hardware to wire colors needed for the install.
http://www.mazdas247.com/forum/showthread.php?t=123663618
Don't know if it is the same for the regular 3 but everything in that guide works for the ms3
I'm not sure what scope of help the OP is looking for, but here's a quick rundown...
More or less you have to get power and audio to the amp (usually) in the trunk.
Power: most people use heavy gauge wire (4 or maybe 8) from the battery (with a fuse) to the trunk. Then use the same size wire to ground the amp. Where you run the wire probably depends on whether you want to see it or not.
Audio: There is 2 ways to do this (that I know of, I'm certainly not an expert).
One is to use "line level" or speaker inputs on an amp. For this you pretty much splice wires into the rear speaker wires and hook them up to the amp. The amp takes that signal and amplifies it. I've never done it this way, but it seems like it would be the easiest. The audio quality suffers though.
The other way is to hook up RCA cables between the head unit and the amp. Buy some long, high quality stereo RCA cables and run them between the trunk/amp and the dashboard. You'll have to snake them through the dash, which is a pain, to the back of the deck. The problem is: I don't think factory head units have RCA outputs, so you'll need to buy a new deck if you're going to go this route. Oh, you'll also need to have an "amp turn on wire" which is a small wire that connects the deck to the amp to remotely turn the amp on when the stereo is on (so it doesn't drain your battery while the engine/stereo is off).
The advantages you get with RCAs is you get a better signal and also sometimes a customized signal. Some decks have a sub-output that only puts out the low frequencies suitable for subwoofers. This will let you control the relative volume from the deck instead of having to go to the trunk to make adjustments. (Got your parents in the back seat? Turn the subs off.)
Oh yeah, if you do get a new deck you have to hook it into the car's wiring. To do this you'll need a "wiring harness" that is compatible with your vehicle. A wiring harness is basically a plug or a set of plugs with a ton of wires coming out of it. You connect those wires to the wiring harness that came with the deck (don't worry, they're color coded for the most part).
Long story short, it's really not very hard, but if you haven't done it before it can be a time consuming challenge. If you can get someone that has done it at least once before it would help a lot!
Crutchfield is expensive (I think they may have gotten better in the last few years), but they have what you need and will let you know all the pieces you need before you complete your order. They also have the tools that are required to get the factory stereo out in the first place. And I think they send you instructions with diagrams/pictures to help with the install. In the end, the extra expense may be worth it for a first-timer.
my friend ran the power wire and amp wire outside of his car in his caddi...you can try that..lol he had a 15 inch and a 3000 watt amp...pretty beastly
i seen it once installed the amp and subs in my truck chevy ss and i got how to hook up an amp and all but i never got how they run the wiring to my stock stereo and hooked it up some weird way the just some how just connected to cables and it sounded good though so im currious how they did that
and to remove stereo should i read manual for that one?
may be it tells how
okay i got the kit today and im wiring the amp currently in my trunk i have to make a whole in the ingine to wire it into a car inside? ans where be best to make it?
and put amp witha ground white and power wire what wire supposed to be between?
I'm guessing you're Russian, I cannot tell what you're asking exactly. I'll try to answer anyway...
You will need to get the positive wire through the "firewall" (the barrier between the engine and the people). There is usually a rubber plug or grommet somewhere between the passenger compartment and the engine compartment. The couple I've seen were near the foot-wells of the passenger side. You may need to peel up the carpet...
WHEN YOU PUT THE WIRE THROUGH THE FIREWALL MAKE SURE THE EDGES OF THE HOLE WILL NOT CUT INTO THE WIRE AND CAUSE A SHORT!! You're messing with a lot of electricity, it would probably be a good idea to get some on-the-job help. MAKE SURE TO FUSE THE WIRE CLOSE TO THE BATTERY!
The ground wire will need to be connected to "a good ground". It's vital that the ground connection be at least as good as the positive connection. What I've done is taken a seatbelt bolt off, cleaned the metal under the bolt with a wire brush (to remove the paint), then put the ground wire on with a couple "star washers" to ensure a good connection. I would say using the seatbelt bolt might not be the best idea ever but is PROBABLY safe. Use good judgment!
thanks sorry about my spelling im kind of bad at it yes im originally from russia now living in cali though
thanks u actually answered
i seen the amp hooked up once in my life in my truck which i sold two days ago now im just wondering how do i now hook up amp to my stock cd player in car im about to run all the wires threw the only problem its late night in cali now lol
i was looking now and i cant find a plug u know where it is ?
i dont wana drill whole lol
I don't know... It's usually kind of hard to find, but then once you know where it is you wonder how you ever missed it.
